I recently test the pixhawk in loiter mode, I find my hexa slowly descends or climbs in this mode until I switch to stabilize mode. I use
a. DJI F550 b. Pixhawk 2.4 c. ArduCopter V3.1.2(e2e3dd1) d. T14SG
My logs and pics has been attached below. I got my THR_MID value according to this page http://copter.ardupilot.com/wiki/ac_throttlemid/
I disarm my hexa in stabilize mode, then adjust the throttle to keep the hexa hovering. As shown in
log and pic also attached. I changed my THR_MID to 500. Is this value correct?
Then I disarm my hexa in loiter mode, the GPS is good and HDOP is below 2. I push the throttle beyond 50% (about 60%), then my hexa climbs up, I pull the throtle to the middle position, but my hexa still climbs up slowly. I pull the throttle below 40%, hexa descents, I push the throtle to the middle position, it dose not stop, continuing to descent. I read the loiter mode and altitude hold mode separately from http://copter.ardupilot.com/wiki/loiter-mode/ http://copter.ardupilot.com/wiki/altholdmode/#Controls
BarAlt(CTUN) WPAlt(I have not find this para…, but DAlt in CTUN), RelAlt(GPS) as show below
log and pic also attached. I want kwon
Is there anything wrong in my operation?
How can I keep the hexa a certain altitude when I put the throttle in middle position in loiter mode?
[quote=“xiazibin”]I recently test the pixhawk in loiter mode, I find my hexa slowly descends or climbs in this mode until I switch to stabilize mode. I use
[quote=“interplanetary”]I spent quite a while debugging a similar mode, and had found an that I had inadvertently checked that I had a SONAR when I did not.
I presume the code was looking for data from it when I was close to the ground, and that was messing the control loop code.[/quote]
Yes!
