First time analyzing a log. Can someone tell me why my copter a 3DR-Y6 lost control.
Was 3rd flight on a clear cold day,about 20F. Winds 5-10 knots.
Log is attached.
Again-what happened?
And how do I prevent it in the future?
Thanks
Kurt B.
Log is attached.
Thanks
Kurt B.
So first off, “lose control” can mean lots of things - I could not tell if you meant that you had crashed, or if you had a flyaway, etc, so I had to look at a few things.
It looks like the copter’s inertial navigation solution went bad on your second battery, with xy errors over 15m. There were no GPS glitches. This suggests two possibilities:
Additionally, you’ve set your iNAV_TC_XY and INAV_TC_Z parameters to slightly higher than default. This weights the accelerometers more and the GPS less, causing the copter to be more susceptible to these effects. These are time constants, and error in position delta measured by accelerometers is quadratic in time. (3/2.5)^2 is 1.44 and (7/5)^2 is 1.96, so I’m guessing your XY errors were 45% larger than it would have been otherwise and your Z was 96% larger than it would’ve been otherwise.
