After doing some maneuvers the copter detects incorrect level position. I recorded a video from the simulator. Even though it stays on flat surface, the HUD shows almost 5 degrees lean angle. Sometimes it drifts quite significantly
Usually that stems from either an hardware issue or from a missconfiguration.
First issue can be solved by reading section 1 of the “How to methodically configure and tune any ArduCopter” and the second issue is addressed in the following sections of the same post.
Following these recommendations will help you solve the problem on your own.
If you do not want to solve it yourself, and can’t be bothered learning new skills, wait for someone else to give you an answer
The example I provided is taken from SITL. So I don’t expect it to be a hardware issue. From my observation, this problem is more noticeable when GPS is turned off (SIM_GPS_DISABLE = 1 in this case) and I’m curious how GPS may affect the drone’s attitude.
My setup is completely without GPS, so I turned it off for EKF3 where possible
EK3_SRC1_POSXY 0
EK3_SRC1_VELXY 0
EK3_SRC1_POSZ 1 # Baro
EK3_SRC1_VELZ 0
EK3_SRC1_YAW 1 # Compass
EK3_SRC2_POSXY 0
EK3_SRC2_VELXY 0
EK3_SRC2_POSZ 1
EK3_SRC2_VELZ 0
EK3_SRC2_YAW 1
What else I can adjust to improve althold performance ?
Nope, disabling as many EKF3 features as possible will not give you better performance nor accuracy.
It will do exactly the opposite of what you want.
Please do read the documentation on GPS denied navigation, and be as little creative as possible.
If the results are still not good enough, then you need to get more expensive IMUs and improve vibration damping
Non GPS navigation documentation is completely focused on different kinds of sensors. But here I don’t have any sensor. At the end of video, I landed completely. Also, I disarmed copter after that (so vibrations should gone away), but misalignment was still there.
what about manual modes like stabilize? I’m curious what is the difference from attitude control to maintain level position in stabilize mode comparing to althold.
