Copter-4.5.6 released!
Copter-4.5.6 has been released as the stable/official build for multicopters and traditional helicopters. It should appear in the ground stations within a couple of hours of this posting. Alternatively you may directly download the binary (aka “.apj” file) from firmware.ardupilot.org.
Changes vs 4.5.5 are in the release notes and also copied below
  1. Board specific enhancements and bug fixes
  • 3DR Control Zero H7 Rev G support
  • CUAV-7-Nano support
  • FoxeerF405v2 servo outputs increased from 9 to 11
  • Holybro Pixhawk6C hi-power peripheral overcurrent reporting fixed
  • iFlight 2RAW H7 support
  • MFT-SEMA100 support
  • TMotorH743 support BMI270 baro
  • ZeroOneX6 support
  1. Minor enhancements and bug fixes
  • Cameras using MAVLink report vendor and model name correctly
  • DroneCAN fix to remove occasional NodeID registration error
  • GPS NMEA and GSoF driver ground course corrected (now always 0 ~ 360 deg)
  • ICP101XX barometer slowed to avoid I2C communication errors
  • IMU temp cal param (INSn_ACCSCAL_Z) stored correctly when bootloader is flashed
  • IMU gyro/accel duplicate id registration fixed to avoid possible pre-arm failure
  • Logging to flash timestamp fix
  • OSD displays ESC temp instead of motor temp
  • PID controller error calculation bug fix (was using target from prev iteration)
  • Relay on MAIN pins fixed
  1. Copter specific fixes
  • Payload place bug fix (climb rate after releasing payload was unreliable)
Thanks as always to the developers and beta testers who contributed to this release!
P.S. we hope to begin beta testing of 4.6.0-beta1 in 2 to 3 weeks
Hi. Not sure how beta testing works but let me know if you need anything specific. I’m currently running 4.5.5 on a quadcopter.
