By the way, Sport mode is very rarely used in the community which is why it is disabled by default. Most users just stick with AltHold mode instead of using Sport.
So I dissapointed some. Were in fact Guided non gps disabled?
P.S. question is closed as I use 4.4.4. as base for my SW mod, but I wuld like to better unerstand AP
Thanks
We haven’t heard anything back from you or the other two who reported issues with the Pixhawk6c compass so I’ve closed the issue for now at least. If we do get some more information from any of you then I’m very happy to re-open.
I posted in another thread as well…in this 4.5.0 beta2 release should the net_enabled parameter be available/visible by default on a pixhawk 5x? I installed the beta firmware as I wanted to try the Ethernet configuration but am not seeing that param in the params list in mission planner. Or do I have to do something special to get that param to show up? Thanks for any help and guidance!
@tridge@bugobliterator, do you think it is sufficient to just remove the hashes? My guess is this is not sufficient because I hit these compile issues
[37/112] ChibiOS: Compiling hal_wdg_lld.c
…/…/modules/ChibiOS/os/hal/ports/STM32/LLD/MACv1/hal_mac_lld.c: In function ‘mac_lld_init’:
…/…/modules/ChibiOS/os/hal/ports/STM32/LLD/MACv1/hal_mac_lld.c:274:7: error: invalid use of void expression
274 | if (!mii_find_phy(ÐD1)) {
make: *** […/…/libraries/AP_HAL_ChibiOS/hwdef/common/chibios_common.mk:243: modules/ChibiOS/obj/hal_mac_lld.o] Error 1
make: *** Waiting for unfinished jobs…
This came up on this morning’s developer call and unfortunately networking has only been enabled on the H7 boards. The Pixhawk5x is an F7 and while networking may run there are concerns that these boards do not have the processing power.
Thank you so much for looking into it. This might be the excuse I need to upgrade to a 6x then. Thanks for all the great stuff the team is doing on this project!!
