4.2.0 is getting close but I’m afraid two little issues have come up meaning there will be one more release candidate. I hope to release that final release candidate (“rc4”) today or tomorrow and then hopefully release 4.2 as the official version one week later (maybe Fri May 20th).
Hi, relatively new to Arducopter, so hope that this is the right place to report issues. Am using Copter-4.2.0-rc3 on a Diatone Roma L5, flashing to a Matek H743 flight controller and using an iFlight 4-in-1 ESC (flashed with BlueJay). As part of the set up, I did a motor test, and all the motors span up in sequence, but when I go to arm to fly, I observe the following behaviour:
Initially, nothing happens. I disarm and arm, use full right yaw when arming, and at some point, 3 of the 4 motors start to spin (on different occasions, it is different motors that don’t spin). Keep on arming and disarming, and eventually, all 4 motors start to spin and then everything appears ok.
Is this something in rc3, or is there something I need to change, check or set?
Hey Randy
Hope you and yours are well. Is there some document that explains what 4.2.0 will be all about. I am thinking about the reason to upgrade. What are the advantages to it. Not sure you can answer that but thought I would ask.
