You will find the answer by following the wiki instruction ! https://ardupilot.org/dev/docs/building-the-code.html
The issue you have is just that you take a zip from github and not use git to get the code. We are using git on the build phase, so it is mandatory !
Hi khancyr.
I couldn’t find good way on ardupilot site because I’m starter…
Ardupilot site show how to build from latest Code.
I think there is no way to build using ‘*.zip’ file on the site maybe…
For use git,
I created now repository on my Github,
cloned to desktop’s folder,
unzip ‘ardupilot-Copter-4.0.3.zip’ file to the folder,
did commit, publish
and, check the same result again.
What’s wrong with me?
I’m waiting your reply again
Thank you.
Follow the instructions on the wiki to setup Master (aka the lastest development). Try a build to unsure that everything is fine.
Then use git checkout copter-4.0.3 and git submodule update --init --recursive
The first git command use git to change master branch to copter-4.0.3 branch that you want. The second command will tell git to update the dependancies to the right version for copter-4.0.3
