This must be the issue re mavlink messages being handled incorrectly in 3.6. … It sounds like this issue doesn’t actually cause problems with the physical movement of the gimbal? I guess it’s the SToRM32 gimbal we are talking about.
that’s one of it, yes. It does. I can’t recall which way around it was, but for one of the messages it leads to 100x smaller gimbal movements (that’s how I found it). It’s unrelated to STorM32.
I’m particularly concerned about any regressions.
well, honestly, I find it hard to understand why one wouldn’t want to add a if which would solve a longstanding issue without any side effects, but instead prefers to theoretize about what the best solution could be. Similarly with the slow update rate in some modes. (both points are unrelated to STorM32 too).
We have had some problems reliably getting datastreams over mavlink to our on-board computer after upgrading to 3.6. Specifically, when we arm the vehicle, a stream requested to 50 Hz will drop to 5 Hz or even less.
After removing some unused features from the scheduler (Optical flow, beacons, etc), it helped a little. Switching to ChibiOS further helped, and we’re reliably getting data in the 30-40 Hz range.
Suspecting that this check has something to do with it?
Its been in the codebase for a while, but might the processor be more busy in this release?
I’ve tested various low-hangig mitigations such as lowering this bound, lowering the max-time of the task and increasing the execution frequency. Resulted in some improvements, but I don’t want to mess with a tested scheduler to much.
Hi @kknet, re the mavlink timing, could you provide a log file or a parameter file? In particular I’d like to check which streams and also the update rate of the main loop. I’ve certainly seen in Rover cases where the message update rate is far lower than it should be but I hadn’t seen this issue with Copter.
Attached are three logs. The first two is with my alterations (only change is disabling features in APM_config.h), and the last is the original (rc 11) where we first discovered this. In the last one, we are requesting raw IMU, RC and attitude at 50 Hz, position at 10 Hz.
Running on a brand new Cube.
Note: The build has some other minor configuration changes, mainly just our own build target to allow for custom default settings. This should not affect the timings, so I was hoping someone else sees the issue on a regular build.
Hi Randy thanks for getting back to me.
I am going to hold off on this issue for now as I am finding a number of power problems I need to resolve. However I can tell you that I was getting a green with an HDOP of 100 and in the basement…
The hud said I had a gps…so status was 1 but it was definitely giving me a green led. That said.I need to settle this power issue as I need to rule out power issues causing strange behavior…
once thats resolved I will try again and if the green led shows I will let you know…logs and all.
@rickyg32, ah, it’s a pixracer! We have a fix for the incorrect LED colours that will go out with 3.6.0 (or the next release candidate if we have to have another). You can give the fix a try by going to the MP’s Install Firmware screen and pressing Ctrl-Q (to load latest) and then push on the multicopter icon. No pressure, to test it though, it’ll be out as a beta or a “soft release” of 3.6.0 later this week.
Re the IMU fast sampling, I think @tridge answered this question before saying that the the Pixhack v3’s IMU is an MPU6000 and is apparently not capable of the fast sampling. From the pixhack website it mentions the MPU9250… I wonder if they’ve changed it.
I’ve had a quick look at the logs and I will ask @priseborough if he also has an opinion on what’s happening.
I don’t see anything really obvious wrong. The 2nd compass (internal) is not good and so it’s good that you’ve set COMPASS_USE2 = 0.
Is there any reason you’re using EKF3? Normally we recommend to stick with EKF2 unless there’s some advanced sensor fusion being used (like Beacons, visual odometry, etc).
Thanks for the logs. I’ve created a new topic to discuss this. In short I’ve reproduced the issue although my setup is a little different. I can see that Copter-3.6.0-rc12 using Nuttx has a slower mavlink output rate than Copter-3.5.7 but Copter-3.6.0 with ChibiOS is a tiny bit faster than 3.5.7.
Hello Randy,
Yes that’s true but after sending him specs and log I have heard nothing. By the way I switched to EK3 and maybe I feel the copter stabilize performance is a bit better.
Thanks
So if indeed the Pixhackv3 is using the MPU6000 IMU then the fast logging won’t be possible I’m afraid.
Re choosing between EKF2 and EKF3, Paul Riseborough has always said that the EKF2 is more reliable and recovers faster in cases where it has gone into a bad state. He’s said that most people should stick with the EKF2 unless they have a specific need for the EKF2. You’re free to do as you choose of course, it’s your vehicle and it’s open source.
@rmackay9 - thanks. I switched to EKF3 because I was getting random dropouts in the compass innovations I may be able to dig up an EKF2 log with similar behaviour (and I see others complaining of random compass switching), although the weather has suddenly turned wintry here so if I can’t it may be a while before I fly again. I also wanted to see whether EKF3 coped better with my high X vibe and high compass interference.
Why would compass 2 be so much worse than compass 3? They are basically in the same place on the pixracer. One calibrates well the other does not (see my post a few up).
Could it be the EKF is looking at compass 2 anyway in some edge case?
@rmackay9 here is a similar log from EKF2. No compass switching that I can see but the second IMU innovations are missing until midway through the flight.
Hi guys,
Could someone comment on what the expected level of UAVCAN functionality in RC12 is? I’ve got a Zubax GNSS 2 to test on the desk: thus far GPS seems to work (excepting for https://github.com/ArduPilot/ardupilot/issues/9579), but not compass and baro. Is there supposed to be support for these? Don’t want to waste people’s time trying to fix things that aren’t ready yet.
Thanks!
