Copter-3.6.0-rc12 available for beta testing
Hi Randy, thanks for the looking at the log. Yes it is an external compass (Radiolink TS 100 mini that has QMC5883L chip). So the driver was detected correctly I think.
Unfortunately I have no idea of what I could check further, I have two TS100 units, both not working on Chibios. And works not very good on NuttX, having strange peaks I’ve described in Compass stop working but remains healthy
I’ve disabled all the peripheral devices to avoid interferences but that did not solved the issue.
I will also check on v3.5.
@rmackay9 here’s a new log with the compass calibrated, I was just hovering. The EKF Mag innovations are all zero as I reported in another thread. Could this be to do with using the compass with the large offsets? It seemed to go away when I excluded the external compass.
Just got round to having another look at this, turns out it works fine just the serial ports are in a funny order.
I try to reorder and test them all…but GPS and other serial things dont works…
I have TX3 and RX3 is serial 1 and TX4 and RX4 is serial 2. You will have to do a full power cycle after you change any serial params.
Anyone know if the OSD for omnibus boards has been fixed in this release?
If not, should I assume it will not be implemented for 3.6?
I think rc12 code was not compiled using current correct hwdef file for kakute f7.
Randy, what exactly code does now if compass-learn is set to 2 - EKF learning?
Cannot get Mavlink telemetry to work on any of the serial ports. Using the Matek 405CTR Tried UART3 (Serial1) and UART1 (Serial3) neither work selecting protocol 1 and Baud 57. If I flash with Arduplane using same serial parameters it works fine and the crossfire picks up all the telemtrey. Is this a bug? Thanks,
BATT FAILSAFE - I could not find the options for BATT_FS anymore. The parameters are available on the full parameters list (MP), but it´s blank at the tab Mandatory Hardware - Fail Safe configuration. I am still able to define the voltage and mA limits, but not the ACTION. The Radio_FS is OK.
PHLD_BRAKE_ANGLE & PHLD_BRAKE_RATE seems to be ignored. I have tried high values, but the behavior did not change at all. The drone brakes very slowly after release the sticks (in PosHold). It drift about 3 to 4 meters before stop. DZ and TRIM were checked and are accordingly.
I am using MP.1.3.58 and FW 3.6.0-RC12.
Thanks in advance.
Hi all
I upgrade my small 250 quad to 3.6.0-r12 from 3.5.7
I performed autotune but. I notice problem when copter is in loiter mode and I try yaw copter rise and down. ( 2-4 m)
Did anyone notice a similar problem
https://drive.google.com/open?id=1VYxvUQr4PM3NhYYmnWs5UzzinO-3ykjV
I had problems similar to this, setting INS_ACCEL_FILTER and PSC_ACCELZ_FILTER to higher values fixed it for me (I am using 40). It could also be a baro problen, but I guess if 3.5.7 works fine then maybe not.
Hey All,
I noticed this weird interaction in my Pixhack v3 running 3.6.0-rc12, where it seems to be overheating, or something cause after a flight, i touched it and it was so hot, it almost burned my finger. Is that normal? Or am i just being weird?
Many thx
I have INS_ACCEL_FILTER = 20 and PSC_ACCZ_FILT= 20 I will try to set it to 40
Regards
Hey all,
The logs for the above question I had
When seeing the logs, i noticed it increases temperature sharply when changing modes, and it is at 80deg Celsius.
If anyone could help.
Logs for Overheating
I have a question.
Might be something I simply never noticed before…but thought I would ask.
so I have my new build on the bench. Transmitter is powered off.
I plug a battery into the quad and I hear mission planner express the different calibrations and such as the machine readies itself.
Finally is says Pre Arm Hardware Safety Switch…wait a minute my tx is still off. Should it not be concerned there is no RC in. It does say throttle below failsafe. If I hit the safety switch it all messages clear and I am ready to go…well sort of…the tx is off so it’s not going to arm.
Oh and the other odd thing is I have a Solid green status led…which the literature says is your good to go GPS acquired. No way that is right, I am in the basement with an hdop of 100.
Is this normal…is it just that i never noticed before
It’s a quirk. Until we see an RC receiver we don’t ever consider it
“bad” for the purposes of the SYS_STATUS mavlink message. This is on
purpose - possibly for RC-less flying (which some people do, relying on
channel-overrides or simply using guided modes.
Looked at the log. The temperature “jumps” because the log is not being recorded while the drone is disarmed, but the temperature keeps increasing. In the Mission Planner log viewer, you can use the “Use Time” checkbox to see that the temperature just increases slowly the whole time, even while disarmed.
I am not familiar with the Pixhack, but certainly 80C is too hot. Is it exposed to direct sunlight? Does it still heat up a lot if you leave it inside?
Thanks Peter Baker…that makes sense.
The only thing then that I am confused about is the LED colour then, but perhaps thats a change thats not been documented yet. Things change so fast around here it’s hard to keep track.
Hey Rick,
Alright thanks for the answer. There is a canopy which covers it from direct sunlight. It does not heat up too inside. Only during flight.
Thats why I had the doubt.
