I am confused how to get the correct UTC time from my flight logs.
Mission Planner displays the UTC time “2021-03-29 13:53:27.000” for GMS = 150825000 and GWk = 2151.
When I try to manually convert the GMS and GWk using python (see code below) I get “2021-03-29 17:53:08”
Code Used: pandas.to_datetime(“1980-01-06 00:00:00”)+pandas.Timedelta(weeks=2151)+pandas.Timedelta(seconds=150825)-pandas.Timedelta(seconds=37)
I used an online converter to check my code and got the same answer minus the leap second correction: “2021-03-29 17:53:45”.
My flight was around 13:53, so Mission Planner is correct. I am confused at how to properly convert the provided GPS time into UTC. What am I missing? Where does Mission Planner get the times in the “-1” column?
