Convert UART to PWM output
I’d like to be able to hook up more servos and motors than the default/aux output channels allow. Is there a way to convert some of the unused UART (or other?) channels into PWM or DSHOT outputs?
Reason:
I’ve modified an eflight convergence using a Pixhawk 4 mini running a custom flight controller and it was epic, but now I’d like to use a smaller flight controller to fly eFlight’s V-22. Most are limited in terms of outputs and I’d love to figure out a way to have more outputs for this and other aircraft.
No. You can’t just convert UART to PWM outs, But you can convert UART to Sbus, Then Convert Sbus to PWM, take a look here Serial Port to Sbus
