Would it be possible to have MP show controlled flight into terrain by taking the waypoint elevation and subtracting the SRTM elevation data (or user dems)? Use different colors for high, med and low probability of collision. Not my idea btw, but a very smart colleague.
I’m on the wrong computer, otherwise I’d get you a screen shot. One you have your waypoints, right click on the map screen. In the menu go to Map Tools and there should be an option to plot the elevation data. You should get a graph that will show your waypoints vs the SRTM data. I’ll try to grab screen shots later if it helps.
for realtime display of this
press control-w and turn on elevation
or as allister said
