Is there a way to test each motor individually?
on Pixhawk, is alredy possible since version 3.1.x from CLI ->test->motors
on APM maybe will be available from 3.2 version
Ciao - Giuseppe
Motor test is available on APM 2.x since Copter 2.4!!!
[youtube]http://www.youtube.com/watch?v=BBdIFZYbFh4[/youtube]
Sorry, I confused it with Motorsync.
Ciao - Giuseppe
Is there any internal tests going on or is it for a user to check motors turn and direction?
It’s exactly for the user to check that the cabling is right.
When i do the motor test from the mission planner, it always say something like “Autopilot didn’t allow the command”. It works as intended if i do the motor test from CLI tho.
IIRC, the buttons in Mission Planner work from 3.2 on. Before 3.2 you have to use CLI.
