Hi wcp1947,
By going to settings, advanced, the only setting I can find is to display HDOP. Nothing else you mention is even visible as an option. Is there another RC I should try, perhaps? I’m on the mailing list for release candidates but don’t believe I’ve seen one after 2.8.1 RC1 was released…
So, I had a look at my SR* params on the pixhawk and something zerod them all out. I got them back to defaults and am now getting attitude and position data (as well as what mode I am in) but I cannot do the following:
[]Load a mission
[]Write a mission
[]Find any mention of Follow Me anywhere (on my friend’s older version there is a setting to enable Follow Me mode - I do not have that option)
[]Arm (I can disarm, though)
[]Download parameters
[]Change Flight Mode
I AM able do to the following:
[]Receive audible feedback on mode changes, arm status, battery levels (even though that option is disabled in settings)
[]Receive Position and Attitude data
[]View satellite count, HDOP
[]Disarm
I am not sure if I can do sensor calibration, and have no desire to try at this time.
In DP2, the Telemetry Link Speed is 57600 (Default), and here are all the stream rates (again, nothing modified, all from default) :
Waypoints,GPS raw, fence data, current waypoint, etc: 2
Attitude: 10
VFR_Hud data: 2
AHRS, Hardware Status, Wind: 2
Position data: 3
RC Override: 50
RC Channel Data: 5
Raw Sensors: 2
Raw Controller: 3
All the while, the radio link in DP2 is showing 100% signal strength, with RSSI at -45, RemRSSI at -45, Noise at -96, RemNoise at -100 (I’m indoors at the moment), Fade at 48-52, and RemFade at 54.
Finally, just a reminder, I can connect to and fully manage the aircraft from Mission Planner using the same radio (in fact it was that radio where I saw the SR* params were wrong and corrected them)
Hoping you’re able help, this is pretty confusing. Thanks in advance!
Josh
