Connections for hidden pins on chip components through Power Rail Configuration
We are designing a GPS chip for a light-show drone. The GPS used is Ublox Zed F9P - RTK. We also have a 3-axis magnetometer on the chip. A 5V input voltage powers it. The MCU used is STM32. The chip size is 5x5 cm.
The components on this chip consist of several hidden pins (ground and VCC pins). These pins are not visible during the design stage in Proteus. They have been assigned either 5v or ground power rail through power rail configuration.
We would like to know if these will work fine or if there should be some special consideration while designing
