hi, I have successfully flashed the 3DR radio with multipoint firmware and I want to connect the base node to mission planner and connect all the vehicles. but I am not able to do so. the module is showing params of the single copter. how can I achieve multiple vehicle flying? please navigate me step by step.
Please assign a unique ID number to each autopilot,(params “SYSID_THIS_mav ”,)
Yes I did attach unique ID to each mav. But the result is same. It is not reading multiple vehicle data.
problem solved. mission planner had some problem with a driver. reinstalled it and now i can connect to both quadrotors.
Prem_Sai - Can you provide a link for the multi-point firmware for the 3DR radio?
Thanks! Appreciate the quick response.
