can someone show me an example of what he has inserted there:
The problem is solved!
Hi- can you please post your working example?
I cannot get connected to my ntrip caster.
User: xx1/xxxxx
Password:yyy
Host:zzz.zzz.zzz.zzz
Port:0000
Mount:RTCM3Net
So I enter: http://xx1/xxxx:yyy@zzz.zzz.zzz.zzz:0000/RTCM3Net
The error is “socket exception 0x80004005: no such host is known”
Entering the user name with “& sol;” rather than a / shows “bad ntrip Responce” HTTP/1.0 401 Unauthorized
The caster is known to work on numerous other devices.
Help would be appreciated!
You cant have a / in the username or password , cannot be removed?
Thanks, I figured that was the problem.
It is doubtful that I can get it removed- as it is issued by a government CORS service. Actually two different states both have the same format.
Any work arounds?
Hi- surprisingly was able to work out a solution with the State that does not include the / character.
So now we are now connected, using the format listed above.
