Hi everyone! We are trying to connect this TFMini Plus lidar sensor to our Cube Orange but when we recieved it we realized the connectors are different, so we would need either a female-female cable to connect using the provided cable OR a male-female adapter to connect the sensor to the GPS2 port directly.
My question is: does anyone know where can I source these types of cables or what does the GPS2 port connector is called so I can look it up on mouser-digikey-aliexpress?
The connection I need to make is between this two connectors in the picture.
Solved. For future reference:
The GPS2 port connector is called JST-GH (1.25mm pitch) 6 pin
The TFMini Plus connector is called MOLEX-GH (1.25mm pitch) 4 pin GH1.25-4P (Molex51021-0400) Picoblade
so you can order the JST-GH housing and crimp pins, and the Picoblade male part of the connector and create your own adapter cable!
