Hello,not sure if this is the right place, but i have searched everywhere else, and had no luck.
My question is specific for the radios, nothing about Arduxxxx or Mission Planner.
I have a bunch of V1 sik radios, and i have the idea of implementing these radios to stream RTCM corrections for RTK surveys.
i have both Air and Ground units, the air units would be connected to RTK capable GNSS recievers, and the Ground would be connected either to a RTK GNSS recierver or to an Ntrip caster to get the corrections from.
I wonder if i can use one ground radio (the one with USB connector) to stream RTCM corrections (as a Base), and connect several air units (Rovers) to get the RTCM corrections.
Is that setup possible?
Thanks.
