okotik
(Okotik)
1
Hello. I use APM 2.8. Firmware 3.6.1 I want connect servo to apm for dumping cargo. I connect servo to A8 port. And setup Mission planer in this way
I use this servo
When I try control this servo from radio it do not react. What i do wrong?
Dave84
(David )
2
Good day, what kind of rc are you using?
Just check also how did you set servo in MP servo controller
dkemxr
(Dave)
3
APM 2.8 with Copter 3.6.1? That Flight Controller will not run Arducopter past 3.2.1.
okotik
(Okotik)
4
Sory i use 3.6.1 with 2.8
okotik
(Okotik)
5
How can i check it. What there have to be?
dkemxr
(Dave)
6
Sorry, if you are using a Flight Controller that looks like this (APM 2.8) you are not using Arducopter 3.6.1
okotik
(Okotik)
7
Yes i use this controler. Or i was wrong it is 3.2.1. But it is do not work
dkemxr
(Dave)
8
I’m just establishing that you posted in the wrong place. Moved to the right one.
