I have been using the usb cable to connect between apm2.5 and pc with no problems. Just installed 915Mhz mavlink. Connects fine for flight data, configuration, etc in flight planner but when I try terminal functions, I just get endless scrolling code, or trash. Both apm2.5 and mavlink radio are from HobbyKing.
Go to terminal mode, press the reset button on the APM and when you see the boot messages in the cli, press return many times until you see the cli prompt
Sent from my Ainol Novo 7 Fire using Tapatalk
dears plz help i have the same issue with terminal session it gives garbage when i connect with both usb or telemetry
@fadymakram,
If you are running ArduCopter v3.2 the CLI function has been removed due to memory capacity constraints and you will get only garbage.
Regards,
TCIII GM
So it is not a hardware failure on APM coz I found sone article talks about that the i2c regulator can cause a terminal failure so I measured the out voltage I fout it is 4.5 v so is that normal thaks buddy for your support
@fadymakram,
The output of the I2C regulator should be 3.3vdc. Are you sure that you are measuring on the correct power pins?
Regards,
TCIII GM
Yes iam sure it is the red and black ports is that can cause the garbage terminal
Hi can any body help me on this I have APM 2.7 and iam using MP 1.3.19.3
channel #3 on the APM board is not working I don.t know why I have all the wires linked correctly
after I saw some reviews I figured out that I can switch this channel with anther channel can any body tell me how I can export the configuration file and how to edit it
thanks alot
