Connecting AntennaTracker with GCS
How can I send the data to the autopilot running AntennaTracker controlling the antenna if my RADIO connection with the UAV is TCP/IP and connects directly to the GCS computer. Looks like if I connect by USB to the antenna autopilot using another instance of MP there is no option…
@Catalin_Pascale,
We’ve got a wiki page here that might help: Multi-Vehicle Flying — Copter documentation
… but it may also be possible if you’re using MP’s Ctrl-F screen’s “MAVLink” button.
Thank you… I was thinking the same… or maybe I use a TCP to TTL converter from the main switch of the GCS and connect it to the tracker…
@rmackay9 Is there a way to trim the types of Mavlink messages to only contain the GPS messages when I use the Ctrl-F MAVLink button?
