i was able to use remoti.it to access the pi from different network and I was able to access pi from Putty but mission planner is not loading, any idea how to fix that please
Did you setup a TCP connection to the pi from within MP?
You can try adding --master=tcp:0.0.0.0:14550, maybe mavproxy doesn’t listen by default.
Familiarize yourself with mavproxy parameters: Startup Options — MAVProxy documentation
Is mavproxy
a requirement? mavlink-router
or cmavlink
might be better choices for a pi.
