Connect RPi3 and pixhawk 4
I’ve bought a new pixhawk 4. I have a RPi3 B+ and I woud like to know if it is possible to connect them together?
Thank you for your help
Yep, definitely possible. You have two options:
  1. Use the USB cable between the Cube and Pi
  2. Connect one of the Cube’s telemetry ports to the Pi’s UART (you may need to build/modify a cable for this)
There’s a page on the wiki with full details: http://ardupilot.org/dev/docs/raspberry-pi-via-mavlink.html
Thank you for for the fast reply.
I thought it would be different, that’s why i asked. I’ll try it and let you know
I have another question. I don’t know what to choose between pix4 and ardupilot firmware. Do you have a suggestion for me please. because I don’t know if I should let the pix4 firmware in the pixhawk 4 or change it to ardupilot. it seems like ardupilot has more community and more application than pix4.
