Computer does not recognize ports
I flashed an omnibus f4v6 aoi with arduplane using betaflight, zadig, and the impulserc driver fixer. Now, when I plug in the board, I can’t find the port to connect the fc in mission planner. I also can’t find the port in device manager, even on show hidden devices. (using windows 11)
I would suggest using DFU-UTIL to load the bootloader and then use Mission Planner to flash the firmware. All other procedures work sometimes, this works every time.
Bootloaders are here:
Bootloaders
