I’m new to Eclipse and Java and Android development (I have a .Net background) but I’d like to play with (and possibly contribute to) the DP code.
I’ve followed the instructions in the Github wiki but I’ve run into a problem, it won’t compile because it’s got code that it’s referencing that’s not found:
[color=#400080]Description Resource Path Location Type
The import it cannot be resolved EditorListFragment.java /FlightDataActivity/src/com/droidplanner/fragments line 3 Java Problem
[/color]
The lines beginning with:
import it.sephiroth.android.library.widget…
in EditorListFragment.java are underlined indicating a problem
In Visual Studio I’d just find the code (I can see some code in Github that seems to match ‘it.sephiroth.android.library.widget’) and add a reference but in Eclipse I can’t find a way of doing it.
Has anyone had the same problem??
Cheers,
Dave
