put it in a folder alongside the Mission Planner source files.
replace “Skeleton_rename_me” with the name of your plugin in every file and filename.
Then add the project to Plugins folder in Mission Planner solution.
Small inconvenience, it will not compile if you build MissionPlanner, you have to build it by right click and select build on the plugin project, then start MissionPlanner.
