I get the following compile error on Debian. Any ideas?
g++ -c -pipe -O2 -D_REENTRANT -Wall -W -fPIE -DQ_LINUX_32 -D_TTY_NOWARN_ -D__STDC_LIMIT_MACROS -DGIT_COMMIT=2.0.15-18-gfc4d734 -DGIT_HASH=fc4d7343c1e24b955ea409d8977fa53c31d3030f -DQT_NO_DEBUG -DMAVLINK_NO_DATA -DQGC_USE_ARDUPILOTMEGA_MESSAGES -DNOMINMAX -DEXTERNAL_USE -DDATADIR="/share" -DPKGDATADIR="" -DQT_NO_DEBUG -DQT_QUICK_LIB -DQT_WEBKITWIDGETS_LIB -DQT_PRINTSUPPORT_LIB -DQT_SVG_LIB -DQT_OPENGL_LIB -DQT_QML_LIB -DQT_WEBKIT_LIB -DQT_WIDGETS_LIB -DQT_TESTLIB_LIB -DQT_SCRIPT_LIB -DQT_SERIALPORT_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_NETWORK_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_TESTCASE_BUILDDIR="/home/pi/apm_planner" -I/usr/lib/arm-linux-gnueabihf/qt5/mkspecs/linux-g++ -I. -IQsLog -isystem /usr/include -isystem /usr/local/include -Ilibs/mavlink/include/mavlink/v1.0 -Ilibs/mavlink/include/mavlink/v1.0/ardupilotmega -Isrc/apps/mavlinkgen -Isrc/apps/mavlinkgen/ui -Isrc/apps/mavlinkgen/generator -Ilibs/eigen -Ilibs/alglib -Ilibs/opmapcontrol/src/core -Ilibs/opmapcontrol/src/internals -Ilibs/opmapcontrol/src/internals/projections -Ilibs/opmapcontrol/src/mapwidget -Ilibs/utils -Ilibs -Ilibs/opmapcontrol -Ilibs/thirdParty/quazip -I/usr/src/3rdparty/zlib -I. -Isrc -Isrc/ui -Isrc/ui/linechart -Isrc/ui/uas -Isrc/ui/map -Isrc/uas -Isrc/comm -Iinclude/ui -Isrc/input -Isrc/lib/qmapcontrol -Isrc/ui/mavlink -Isrc/ui/param -Isrc/ui/watchdog -Isrc/ui/map3D -Isrc/ui/mission -Isrc/ui/designer -Isrc/ui/configuration -Isrc/output -isystem /usr/include/arm-linux-gnueabihf/qt5 -isystem /usr/include/arm-linux-gnueabihf/qt5/QtQuick -isystem /usr/include/arm-linux-gnueabihf/qt5/QtWebKitWidgets -isystem /usr/include/arm-linux-gnueabihf/qt5/QtPrintSupport -isystem /usr/include/arm-linux-gnueabihf/qt5/QtSvg -isystem /usr/include/arm-linux-gnueabihf/qt5/QtOpenGL -isystem /usr/include/arm-linux-gnueabihf/qt5/QtQml -isystem /usr/include/arm-linux-gnueabihf/qt5/QtWebKit -isystem /usr/include/arm-linux-gnueabihf/qt5/QtWidgets -isystem /usr/include/arm-linux-gnueabihf/qt5/QtTest -isystem /usr/include/arm-linux-gnueabihf/qt5/QtScript -isystem /usr/include/arm-linux-gnueabihf/qt5/QtSerialPort -isystem /usr/include/arm-linux-gnueabihf/qt5/QtSql -isystem /usr/include/arm-linux-gnueabihf/qt5/QtXml -isystem /usr/include/arm-linux-gnueabihf/qt5/QtNetwork -isystem /usr/include/arm-linux-gnueabihf/qt5/QtGui -isystem /usr/include/arm-linux-gnueabihf/qt5/QtCore -Ibuild-release/moc -Ibuild-release/ui -o build-release/obj/CameraView.o src/ui/CameraView.cc
src/ui/CameraView.cc: In member function ‘virtual void CameraView::paintGL()’:
src/ui/CameraView.cc:240:94: error: ‘glDrawPixels’ was not declared in this scope
src/ui/CameraView.cc: In member function ‘virtual void CameraView::resizeGL(int, int)’:
src/ui/CameraView.cc:246:18: error: ‘GL_PROJECTION’ was not declared in this scope
src/ui/CameraView.cc:246:31: error: ‘glMatrixMode’ was not declared in this scope
src/ui/CameraView.cc:247:20: error: ‘glLoadIdentity’ was not declared in this scope
src/ui/CameraView.cc:248:30: error: ‘glOrtho’ was not declared in this scope
src/ui/CameraView.cc:249:18: error: ‘GL_MODELVIEW’ was not declared in this scope
make: *** [build-release/obj/CameraView.o] Error 1
