Hi, I have a very complete APM1.0 controller board used in a hex copter that I would like to use in a rover. Will the rover SW be supported on this board?
Thank you,
Rodney Kugizaki
Thank you,
Rodney Kugizaki
@rkugizaki,
The present ArduRover2 v2.42 code will fit on an AMP1.4 which has uses an Atmel 2560 mcu. The APM1.0 uses an Atmel 1280 mcu which has less memory and I do not know if the code will fit on the APM1.0. All I can say is see if the MP will load it without an overflow message showing up.
Regards,
TCIII ArduRover2 Developer
