I make an accell calibration followed by a compass calibration. It works fine. When mowing the copter, I check that the compass is reading the correct headings, and I can arm the Copter.
When I come back the next day I can not arm the copter and the compass does not read the correct headings. When arming I get readings like compass variance error and mag field error. I tried another GPS/Compass unit, but this makes no difference.
I tried to mount it well away from any magnets, and I get the same routine.
FC and Compass is mounted in the same direction. Unfortunately there is another error on the logging, so I can not upload a log file.
Does anyone have an idea what can be wrong?
I mean “error compass variance.”
I just made another test. The copter is equipped with magnets. When the GPS/Compass unit is 9 cm from the magnets the problem arises. When I move the GPS/Compass unit 15 cm (6 inches) from the magnets, the problem seems to disappear.
I will move around with things on the copter and return.
Mowing the GPS/Compass 15 cm (6 inches) from the nearest magnet seems to have solve the issue - so far. I will try again at the end of the day and return with status.
Hope you are still able to maintain the drone CG. Wish you success on your flight.
It seems that this did the trick. Keep Compass and Magnets apart. Yes, I have moved the batteri I little forward, so balance is maintained.
