I’m unable to change compass orientation in the Compass Setup page.
The dropdown seems to be disabled–when I click on it, nothing happens. If I change COMPASS2_ORIENT parameter directly (to 6 in this case), the dropdown reflects the correct value.
COMPASS2_ORIENT
It’s not changed there only noted what’s configured. And read the answer to your other post about setting it.
Thank you. The drop-down metaphor confused me–it suggests that the user may select from a number of options.
