Compass learning
Hi Bill and Chris,
have you ever looked at this?
10 days ago Tridge asked for testers. What do you think of trying that out with a Heli?
Well, It is already on master, although I didn’t check if it is enabled for TradHeli. It works reasonably well on copters, so I don’t see why wouldn’t work on Helis
It is available for all vehicle types, including helis.
Yes, it should work well for helis, and will be useful for large helis I think
I agree. I plan to try this out. If you’ve ever tried to calibrate the compass on a 35-40 lb helicopter with a 6-8ft main rotor, it’s not fun even with the blades off.
Chris,
thanks for looking in to this!
It’s bad enough on my 600! (~13lbs AUW)
Chris, could you find a few minutes to check the FW with auto compass calib. in it, so I know it is safe to use in a Heli? I have never used any special Test FW before other than those from your own link. Thanks.
Luis,
have you flown Arducopter -dev versions?
I have just loaded ArduCopter V3.7.0-dev quad into my drone. I want to try the in-flight compass learning with my drone first before I take the risk with my Helis.
To use -dev FW is a first for me and I hope this will go well.
Hi
I have been flying copters with master, but everything that concerns Helis I always play “chicken” and use only tested / master versions :relaxed:
That is why I asked Chris to try it first. He got better nerves than myself, I am sure.
Last time I tested some weird parameters on a Heli with 3.6RC I forgot to be at 10 mistakes above the ground :slight_smile: and managed to completely destroy a very nice 700…
@FRED_GOEDDERT sorry, I have had a very busy week with stuff, and just have not had a chance to get to testing the compass learning yet.
Master is in a state of flux right now with new things going in all the time. That’s why, with Heli, I prefer to develop on current stable for testing, then port it to master later. I’ve been working on an internal governor for ArduPilot (along with a couple other new things) and haven’t even had time this week to work on that much.
No problem Chris, I will try the drone to see how it works even the drone has already a good compass calib. The weather here is not suitable at the moment.
I will not do the Helis before I see your experience with the in-flight compass calib. Take your time don’t worry about me.
Just tried the quad (Pixracer) with Master. It did not work. Went during arming straight into FailSave mode.
3 times I tried always got FailSave. So immediately I loaded back 3.6.2-rc3 chibios and the drone hovered in AltHold and Loiter beautifully to drain the battery for me. I cannot fly around in my small backyard.
  • In-flight compass calib for me, not yet. Is not important for me with the Quad.
    But I want that for my Helis definitely.
