I found instructions before, but can’t for the life of me find them again. I’m setting those parameters, then ARMING, running around in circles for 10 minutes or so, then DISARMING, and the COMPASS_OFS_xyz aren’t changing even after a “refresh parameters”.
Rover certainly saves the compass offsets once per minute and I’ve seen the PARM messages in the logs that show that the compass offsets are being saved. I’m unsure if the learning actually works though…
What do you need to set to have them saved, and/or where are they being saved? I know they are in the MAG messages in the dataflash logs, but they never seem to change.
Can you post your relevant parameters for how you’re seeing them being saved / changed?
Ahh, I’ve dug through the dataflash - it IS writing the offsets, they’re just the same ones set in MP over and over again!
It looks a lot like learning isn’t working, although the EKF is successfully calculating the required delta in offsets (XKF2.MagX etc). Maybe it’s the transcription of those that’s the problem.
Yes, it’s saving unchanged compass offsets. You may be right that it’s some kind of copying that’s going wrong. I see Copter has this bit of code in motors.cpp that gets the offsets from the EKF and saves them to the compass… so perhaps we need to do this as well in rover… I’ve created an issue for this item as well.
