I have put the propellers such that quad pushes itself down. I then armed the motors in stabilize mode and increased throttle to 60%. I also moved the throttle stick up and down quickly to get surge of current. During this I was checking my total magnetic field reading in the status of mission planner which did not vary by more than 50 mGauss.
Also EKF variance was less than 0.5 all times as seen in HUD.
But when I do compass-mot calibration in mission planner i see huge interference of 70-80% at 40% throttle.
If there is interference why does it not seen in the first case.
I did a small test on auto mode as well, log attached below.
The EKF normalized innovation does not seem to cross 0.5 Log
Can you please look at the compass logs here and share some insights?
This is Li-ion battery, 4s.
When i run magfit for this same flight I donot get any values for compass_dia_ and compass_odi_. You are able to get these values as well.
I am using mozilla firefox web browser for magfit web tool.
Also I am not able to check boxes of “offsets and scale”, “offsets and iron boxes” in magfit.
This is small quad. I cannot put the compass further away from battery. The distance is 4 cm now.
Can you please tell some other way to arrest this magnetic interference?
