are you calibrating the compass on the apm itself ? if not plug the GPS/Compass in then it will work
if you Calibrating the compass on the apm itself it dont calibrate i tried it 100 more times nothing seem to work but when i connect my GPs /Compass it then calibrates
Please help me.I calibrated it sucessfuly before but when i installed the new firmware in APM 2.8 it was showing error 99.Please help me i am not able to move further because of this problem.Thankyou
I also tried uninstalling and installing the mission planner.When i tried first time it worked!!!
But when i tried second time it showed error agian!!!
Now i am trying but not happening.
It was problem in mission planner.try uninstalling and installing mission planner.But calibrate it as it shows white points.dont miss it!
If you get the olution then please tell me.
I am stuck now
HI i am darshit bharucha only but using another account.
I solved the compass clibration error 99 by following these steps:
1.if you have connected the gps wire under the gps socket just remove from under that socket.
2.leave it for one minute.
3.then connect it in i2c socket.
4.then connect to your mission planner.
then disconnect and remove the usb.
5.then remove it from i2c socket and leave it for 1 minute.
6.then connect it to the socket below the gps again.
7.then connect it to mission planner.
8.then try calibrating your compass.
