I am currently working on a project where I try to control the flight controller from the companion computer (ESP32)
The companion computer is running this firmware : ESP32-MAVLink
I can retreive telemetries and arm the drone via MAVLink (connected with TX/RX with the flight controller)
When I try to change the flight mode to GUIDED_DISARMED, I get an error from the flight controller : Setting mode to 88. Command 176 result code 2
I get the same result code when trying to set other flight modes.
As I have seen while doing research, this result code means that the command is invalid ? see MAV_RESULT
I have disabled safety checks and EKF thinking that it was causing a problem, but the result is still the same
STABILIZE = 0, // manual airframe angle with manual throttle
ACRO = 1, // manual body-frame angular rate with manual throttle
ALT_HOLD = 2, // manual airframe angle with automatic throttle
AUTO = 3, // fully automatic waypoint control using mission commands
GUIDED = 4, // fully automatic fly to coordinate or fly at velocity/direction using GCS immediate commands
LOITER = 5, // automatic horizontal acceleration with automatic throttle
RTL = 6, // automatic return to launching point
CIRCLE = 7, // automatic circular flight with automatic throttle
LAND = 9, // automatic landing with horizontal position control
DRIFT = 11, // semi-autonomous position, yaw and throttle control
SPORT = 13, // manual earth-frame angular rate control with manual throttle
FLIP = 14, // automatically flip the vehicle on the roll axis
AUTOTUNE = 15, // automatically tune the vehicle's roll and pitch gains
POSHOLD = 16, // automatic position hold with manual override, with automatic throttle
BRAKE = 17, // full-brake using inertial/GPS system, no pilot input
THROW = 18, // throw to launch mode using inertial/GPS system, no pilot input
AVOID_ADSB = 19, // automatic avoidance of obstacles in the macro scale - e.g. full-sized aircraft
GUIDED_NOGPS = 20, // guided mode but only accepts attitude and altitude
SMART_RTL = 21, // SMART_RTL returns to home by retracing its steps
FLOWHOLD = 22, // FLOWHOLD holds position with optical flow without rangefinder
FOLLOW = 23, // follow attempts to follow another vehicle or ground station
ZIGZAG = 24, // ZIGZAG mode is able to fly in a zigzag manner with predefined point A and point B
SYSTEMID = 25, // System ID mode produces automated system identification signals in the controllers
AUTOROTATE = 26, // Autonomous autorotation
AUTO_RTL = 27, // Auto RTL, this is not a true mode, AUTO will report as this mode if entered to perform a DO_LAND_START Landing sequence
TURTLE = 28, // Flip over after crash
From what i have seen that libary is custom for that project, you would need to modify it for use with ardupilot, it probably wouldnt take that much to get it compatible, flight mode numbers would be the main issue i see.
