I was wondering if there is a code I could use in the Mission Planner command box that would refresh my GDAL imagery.
To explain, right now I am trying to find a solution to refresh the imagery I am using as I would like to import a new geotiff that would have information loaded during the previous flight.
You can add imagery on the fly, but cannot delete without restarting Mission Planner.
Put your geotiff files into a folder and press CTRL-F, select Custom GDAL button and select the folder.
Images are loaded from the folder and will be available immediately.
Once the folder is selected, then MP will load the images from this folder at every start.
