Hello community,
I’m in the process of building a coaxial drone and am seeking some advice on Firmware Selection & configure to handle my specific setup. is there any specific firmware or frame type is available for the variable pitch coaxial drone.
My drone design consists of two rotors: the top rotor is 1 fixed-pitch, and the lower rotor has variable-pitch blades. I want to ensure that I use the correct firmware and frame type for my build.
Here are the key details of my setup:
- Top Rotor:** Fixed-pitch propeller.
- Bottom Rotor:** Variable-pitch propeller, which I intend to control for adjusting thrust.
- Frame Type:** Coaxial (with one rotor above the other, aligned along the same axis).
I’ve come across some general coaxial drone projects (such as the T-Drone open-source build) and found that they often use custom settings, so I’m open to suggestions on how to modify ArduPilot to fit this design.
T-Drone Link: Tdrone----Open source coaxial drone! - Blogs - diydrones
Any insights or suggestions would be greatly appreciated. Thank you!
