I want to start logging the data when the drone is armed and stop logging when the drone is disarmed. To do so, I want to first check if the drone is armed or not if the drone is armed or not. I have used the following code:
import time
from pymavlink import mavutil
import val # logging file
# create a MAVLink connection
master = mavutil.mavlink_connection('udpin:127.0.0.1:14551')
# check if the drone is armed
while True:
armed = False
# get the current system status
msg = master.recv_match(type='HEARTBEAT', blocking=True)
armed = (msg.base_mode & mavutil.mavlink.MAV_MODE_FLAG_SAFETY_ARMED)
if armed:
print('Drone is armed')
val.s_info(master,'on')
else:
print('Drone is disarmed')
time.sleep(1)
This code is working on SITL, Pixhawk connected to SITL and pizero. But it is showing the following results even though it is armed in the case of pi64 and pi4:
Drone is armed
Drone is disarmed
Drone is disarmed
Drone is armed
Drone is disarmed
Drone is disarmed
Drone is armed
Drone is disarmed
Drone is disarmed
Drone is armed
Drone is disarmed
Drone is disarmed
Drone is disarmed
Drone is disarmed
What is the issue here and how can I fix it? I would really appreciate if someone could help me.
