How do you check, or what command do you send via pymavlink/mavutils to check to see what the current Mode the vehicle is in? Below can change the modes but how do I know what mode state the vehicle is in currently?
import sys
from pymavlink import mavutil
# Create the connection
master = mavutil.mavlink_connection('udpin:0.0.0.0:14550')
# Wait a heartbeat before sending commands
master.wait_heartbeat()
# Choose a mode
mode = 'STABILIZE'
# Get mode ID
mode_id = master.mode_mapping()[mode]
# Set new mode
master.mav.set_mode_send(
master.target_system,
mavutil.mavlink.MAV_MODE_FLAG_CUSTOM_MODE_ENABLED,
mode_id)
You can check out HEARTBEAT messages to get the flight mode. But I believe you need to enable receiving messages first. Something like this:
# Insert this after connecting to autopilot, not sure if needed
master.mav.request_data_stream_send(master.target_system, master.target_component, mavutil.mavlink.MAV_DATA_STREAM_ALL, 1, 1)
# Get HEARTBEAT message
msg = master.recv_match(type = 'HEARTBEAT', blocking = False)
if msg:
mode = mavutil.mode_string_v10(msg)
Also, I would do it in a separate infinte loop so you don’t miss any message.
I tried the above code. It does pull the mode and I receive “HOLD” as an output. However when I change the mode to guided and run the code again it still says “HOLD”. I am wondering if this mode message is referring to the initial mode at startup (which I have as HOLD).
