Heya, assume this is the right place to log a Bug?
Have discovered if the MAP parameter is changed, for instance from channel 2 to channel 7 -
Radio Calibration will display the correct bars moving and the correct values, and the correct channel is being outputted/inputted BUT, Mission planner doesnt seem to take the remapped channel into account when it actually writes the calibration, so the values for channel 2 will still be used for channel 7.
In my case, its writing the center and min/max ranges of my LH slider on the radio instead of the values of the elevator stick
