Hi to all,
I’m trying to make the copter fly indoor with a rangefinder and a Pix4Flow. The same copter flies correctly outdoor with GPS.
Indoor I’m using this script to take off:
def arm_and_takeoffNoGPS(Target, vehicle):
#Arm the vehicle print 'ENTERING LOITER MODE' while not vehicle.mode == 'LOITER':
vehicle.mode = VehicleMode("LOITER") time.sleep(0.05) print 'LOITER MODE SET' vehicle.armed = True while not vehicle.armed: time.sleep(1) #Waiting for armed #Take Off thrust = 0.8 while True: current_altitude = vehicle.location.global_relative_frame.alt print('Vehicle current altitude is: %f', current_altitude) if current_altitude >= Target * 0.95: break elif current_altitude >= Target * 0.6: thrust = 0.8 set_attitude(vehicle, thrust=thrust) time.sleep(0.05)
In this way the copter reaches the right altitude but when I change the flight mode to loiter in order to stabilize the copter in its current position the drone instantaneously falls down.
In alternative to this approach I tried to use the dronekit simple_takeoff function:
def arm_and_simple_takeoff(Target, vehicle):
#my_location_alt = vehicle.location.global_frame #my_location_alt.alt = 0 #vehicle.home_location = my_location_alt print 'ENTERING LOITER MODE' while not vehicle.mode == 'LOITER': vehicle.mode = VehicleMode("LOITER") time.sleep(0.05) print 'LOITER MODE SET' vehicle.armed = True vehicle.flush() while not vehicle.armed: time.sleep(1) # Waiting for armed vehicle.simple_takeoff(Target) # Wait until the vehicle reaches a safe height before processing the goto (otherwise the command # after Vehicle.simple_takeoff will execute immediately). while True: print " Altitude: ", vehicle.location.global_relative_frame.alt # Break and return from function just below target altitude. if vehicle.location.global_relative_frame.alt >= Target * 0.95: print "Reached target altitude" break time.sleep(1)
In this case the motors rotate for a few seconds and after that the copter turns disarmed.
I attach my parameters configuration if it could help.
param.param (13.5 KB)
Thank you in advance.
Francesco
