When i connect to my copter/plane via uhf serial modules mission planner overrites my telemetry rates with the default 5,2,2,2,2 rates. This is too high for my serial modules and i need to reduce them each time i connect. Is there a way to stop this behaviour or change mission planners default telemetry rates?
mission planners defaults are on the mission planner options screen. just change them there.
How do i access it?
If your referring to -> Config/Tuning -> Planner
These also keep defaulting to 5,2,2,2,2 each time i connect
yes, look at rateattitude in the flight data status screen as well.
- open mp
- goto settings
- change rates
- connect
- mp will request the rates on connect
- mp rerequests if the rate does not match
