Changing landing parameters between landing attempts
I am performing auto-landing tests again with a new airplane and want to try varying the LAND_FLARE_ALT, LAND_FLARE_SEC parameter values between landing attempts.
If I change the values in Mission Planner, then write them, are the new values in effect, or do I need to power-cycle the flight controller to have them take effect?
I’m using an mRo Pixracer and Arduplane 3.8.5.
Thanks,
Paul
They’ll be in effect. I do that often without rebooting.
Thanks for the information Nathan.
I made a change, but it had little affect. I wanted to make sure it did not work. I cannot solve the problem of the airplane flying past the landing spot in auto landings.
Paul
