I would like to change transmission rate of few messages.
I would like to turn off sending RAW_IMU
In ardupilotmega.py there is code
def request_data_stream_send(self, target_system, target_component, req_stream_id, req_message_rate, start_stop, force_mavlink1=False):
THIS INTERFACE IS DEPRECATED. USE SET_MESSAGE_INTERVAL INSTEAD.
target_system : The target requested to send the message stream. (uint8_t)
target_component : The target requested to send the message stream. (uint8_t)
req_stream_id : The ID of the requested data stream (uint8_t)
req_message_rate : The requested message rate (uint16_t)
start_stop : 1 to start sending, 0 to stop sending. (uint8_t)
based on the codehttps://github.com/ArduPilot/pymavlink/blob/master/examples/apmsetrate.py below, I wrote something like that
autopilot = mavutil.mavlink_connection('udp:127.0.0.1:14551')
autopilot.mav.request_data_stream_send(autopilot.target_system, autopilot.target_component, 27, 1, 0 )
Despite sending the following command, the frequency of receiving msg with id 27 does not change. I do not know if the target ID is valid or component ID. Has anyone made similar experiments? What should I change in the code. Thanks for any repply!
