I would like to change the HUD size manually. But the code forcely change the size by hud1.doresize(). And no data is updated. I don’t know why ? Please help me.
Hi !
Since the solution is quite straightforward if you have adequate c# and winforms background I assume that you somehow not in possession of such knowledge.
Also assuming it is a paid project that you are working on. Based on that I recommend to hire somebody who has the necessary knowledge instead of freeloading on the forum
– disclaimer: I know it sounds grumpy, but I see more and more people who trying to exploit the community for doing paid projects without appropriate knowledge. If this is not the case with you, then I do apologize.
Thank you. I’ll try to sort out
