This is for Mission Planner 1.3.10, build 1.1.5369.11976
I want to make my WP Speed adjustable from 400 cm/sec to 1200 cm/sec via the channel 6 knob via the Extended Tuning screen. However the “Min” and “Max” fields will only accept values below 32.7670. Any values input above that value simply shows 32.7670. In addition, the WP Nav Speed always remains at zero. There is no response to knob changes.
I tested my setup by setting other Chan 6 options to my knob and they respond as usual. But the WP Nav Speed adjust is broke.
As another data point for this problem I went into the Full Parameter List and manually changed TUNE_LOW to 400 and TUNE_HIGH to 1200 and wrote the parameters. Returning to the Extended Tuning screen and doing a refresh, the tuning range min is displayed as 0.400 and the max is displayed as 1.200. And no matter how I adjust my chan 6 knob, the displayed WP Speed stays at 0.
It seems like a decimal place has slipped a bit in the code.
Edit: PS, This is running 3.2 RC10 on a Pixhawk.
