Cartographer SLAM does not work with Rover-4.1.0
Hello everyone,
Is it no longer possible to implement SLAM in Rover-4.1.0?
Now I’m trying to implement Cartographer SLAM by looking at this document.
Last day I was able to get ROVER running autonomously indoors using a Pixhawk CUBE Black with Rover-4.0.0 installed and a Jetson Xavier NX.
And today, after installing Rover-4.1.0 rc3 on Pixhawk, the “VISION_POSITION_ESTIMATE” data is no longer sent from Jetson to Pixhawk.
I re-installed Rover-4.0.0 on Pixhawk again, and that fixed this problem.
Is SLAM support going to end with Rover-4.0.0?
Or do I need additional changes in the full parameter list to run indoor autonomous driving with SLAM in ROVER-4.1.0?
Hi @SpreadKnowledge,
We’ve actually improved support for external position estimates in 4.1 so I’m not sure why it isn’t working.
how do you know that the VISION_POSITION_ESTIMATE data is not being sent by ROS? Are you checking with MP’s mavlink inspector or is it just a warning on the HUD?
My two guesses are:
  1. we’ve changed some messages that ROS was relying on so it won’t start sending
  2. the VISO_TYPE parameter needs to be set
If you’ve got logs of it working and not working that might help figure out what’s going on.
Txs for giving this a try and reporting back!
@SpreadKnowledge,
Can you also check that Rover-4.1.0-rc3 is installed? -rc2 had a problem with auto detection of serial port flow control which could cause problems if Telem1 or Telem2 were used with a companion computer connected using a serial cable with only 4 pins (e.g. no flow control).
Thanks for replying!
I installed Rover-4.0.0 and Rover-4.1.0 firmware to Pixhawk again today to check Cartographer SLAM operation.
I opened the “MAVlink Inspector” window and confirmed that Jetson was sending location information to Pixhawk with Rover-4.1.0 rc3 firmware installed.
However, the HUD displayed the error message “Unhealty AHRS” and the Rover icon did not appear on the map when I clicked on “Set EKF Origin”.
Pixhawk gets the location information sent from Jetson via the Telem2 port, which is connected to only three pins: TX, RX, and GND.
The official documentation says to use EKF2, but I think there is a problem here.
@SpreadKnowledge,
Ah, ok. Those docs haven’t been updated in a while so you should definitely use EKF3 and then set VISO_TYPE = 2 and the EK3_SRC_xxx parameters.
The setup is most like the setup for the T265.
Rover-4.1 also supports GPS/Non-GPS transitions.
Thanks for the advice!
Finally, I have confirmed that I can run autonomous driving with Cartographer SLAM using Pixhawk with Rover-4.1.0 firmware installed.
You are right, changing to EKF3 instead of EKF2 was the key.
The following is the full parameter list that I have changed. Basically, it is the same as the one in the T265 setup.
I hope it will be helpful for someone else to do the same thing as me in the future.
SSERIAL2_PROTOCOL = 2
SERIAL2_BAUD = 115
AHRS_EKF_TYPE = 3
EK2_ENABLE = 0
EK3_ENABLE = 1
EK3_SRC1_POSXY = 6
EK3_SRC1_POSZ = 1
EK3_SRC1_VELXY = 6
EK3_SRC1_VELZ = 6
EKF3_SRC1_YAW = 6
GPS_TYPE = 0
VISO_TYPE = 1 (MAVLink)
COMPASS_USE = 0
COMPASS_USE2 = 0
COMPASS_USE3 = 0
Now that I’ve confirmed that ROVER-4.1.0 can also use Cartographer SLAM, so I’ll be able to use RTK-GNSS and Cartographer SLAM together for both outdoor and indoor autonomous driving.
Thank you very much for this!
Great that you got it working! I’ll add it to my to-do list to update the wiki with the new parameter values for 4.1
I saw you published a YouTube video as well on this subject so I look forward to watching that, txs!
is slam for rover supported using ros2 , or it is not
