Application: use a companion compute to send mavlink commands in order to pilot an autonomous boat.
Goal: be able to use manual mode and then be able to switch to automodes such as loiter and RTL
Approach: arm the vehicle, put it in manual mode and then use RC_OVERRIDE commands like this:
data[3] = 1500+yaw_delta yaw pos
master.mav.rc_channels_override_send(master.target_system, master.target_component, *data)
Issue: can’t yaw or thrust in manual mode using rc overrides.
I have set the following parameters for skid steering:
SERVO5_FUNCTION, 74
SERVO3_FUNCTION, 73
Any help much appreciated!
