I need to be able to change my Net ID while in the field.
My telemetry radios connect fine through mission planner.
With MP disconnected and the Air Module turned off, pressing ‘Load Settings’ will populate the ‘Local’ settings.
With MP disconnected, and the Air Module is powered up, I cannot connect to the Ground Module using the 3DR Radio GUI. I get “Failed to Enter Command Mode” when pressing ‘Load Settings’.
Both Modules were SiK 1.7, then I pressed the ‘Upload Firmware (Local)’ button and changed the Ground Mod to 1.9. The modules still connect to each other via mission planner.
I have the same problem and also I found the same solution suggested by RogelioN.
Nevertheless, I think that is a bug. I don`t know if that is a problem of Mission planner or is a problem of the radios.
I start to suffer it after update to sik 1.9
You mean I have to use an FTDI cable just to change the NetID? That isn’t very field friendly. What’s the point if the “Copy Settings” button.
Must be a bug. I tried MP 2.96 and 3.0. I tried SiK 1.7 and 1.9. I tried different radios and different computers.
I haven’t pushed any distance limits since upgrading to 1.9.
I sure hope it doesn’t lower my range! I’ll have to try. I use and RFD900 on the ground and a 3DR in the air.
